OK, I can't take credit for this mod. I came across something similar a long while ago, posted on a forum somewhere. Seemed like a logical idea so I ran with it. I do have a DieselSite Filtration system enroute but I wanted some kind of solution in the meantime, and I'm glad I did.
So what is it? 1990 Ford F250 w/5.8L fuel filter. As you can see it's inline with the degas bottle return line so only a small amount of coolant is filtered while running. The micron rating for a gasoline filter is more then fine enough for cooling system junk. Pressure isn't an issue either. So far no problems with the heat either, and I don't expect there to be any. Install is only a few minutes.
But how well does it work? Well first of all before I installed the filter I did a complete drain and flush, refilled with just water and Prestone Super Cleaner, then drove it for a week as per the instructions. Drained out the crud, reflushed until clear, refilled with water and VC9. Ran the truck for an hour then took it for a 20 mile drive. Drained, flushed a few times until clear and then refilled with Premium Gold. All flushing done with heat on full, also removed t-stat for flushes. I couldn't have flushed this truck more.
So here it is, after less than 100 miles from the final flush. That's a lot of abrasive sand and I've only shown half of what came out. The filter was absolutely nowhere near plugged. I reverse flushed it and reinstalled. I have a 2000 mile 14,000lb tow next week and I'll update then. It's a cheap and dirty mod but it did work quite well and shows that the sand problem is a real killer for these motors, and no matter how many flushes you do the sand keeps coming.
EDIT: To alleviate any fears of the filter plugging, just add a couple "Y"s and an extra section of line around the filter. That will give you a failsafe should the filter load up, additionally everything can be moved lower to better hide the installation. But whatever you do.......DO SOMETHING! Compulsory for the 6.0L
