1 - 12 of 12 Posts
? my 97 250 4x4 ps with skyjacker 4" lift can I put the 22"" wheels &tires like 08
I would love for my truck to look like them new ones. would i have to modify the inside of my fender or what?
duct tape & zip ties
You can put 22 inch rims on it yes. But I believe the lug pattern for your truck is differnt then the 08 trucks. So unless you can change the lug pattern of your truck 08 rims will not work.
they wouldn't rub every time i turned it
I have 17
I have 17" I traded for off a hummer what size tires these are 315"s
315's are 35"+- FYI get that piece of crap K&N off before you loose your engine!!! Get a Tymar.
Cary
a 315 is the thread width, the tire height is dependent on the aspect ratio, usually 70 or 75 (the sidewall height is either 70 or 75% of the thread width). it also depends on your wheel size. so basically a 315 can be a 31 or a 37 or anything in between. so if your running a 22" wheel w/ an aspect ratio of 75% and a thread width of 315mm, the overall tire size would be 40.6. someone w/ more knowledge please correct me if im wrong?:dunno:
1 - 12 of 12 Posts
