1 - 20 of 68 Posts
Machinist & Fabricator
if you have an IDI, and you frequent these forums, then maybe you have seen this.
if not, heres a lill somthing for you i have in the works.
94 7.3 IDIT w/ 093 ATS F450 Zf5 4wd
Blow me to Bermuda!
Haha, that's bad ***. Haven't been on OB in a while. Need to check in...
There's a 6-door 6.4 here in town that blows my mind when I see it!
oah how i screwed that up!
and neither of you caught it! lol not even myself!
this is obviouslly not an 86... :)
its an 87!
Reactions: SparkyF250
Blow me to Bermuda!
lol I was looking at the doors and nothing else.
The front-end is a brick nose, not slant.
Still nice :thumb:
In that engine pic...is that a Turbo? You add that on, or is it the later Turbo IDI engine?
i thought i changed the slant to brick also?
i have an 86 here im putting some work into for a buddy, im all bass akwards!
thats a dead stock 94 IDI with an ATS 093.
picked up that badboy for super cheap! 600 bucks with 98k on it.
my 6.9 would warm up and knock like the police at your door.
it had to go
Blow me to Bermuda!
im innocent until proven guilty in a court of law! or is that guilty until proven innocent?
Discussion Starter #10 (Edited)
thats a pretty cool project
Discussion Starter #12
electric windows are next! the kits will be here saturday
Discussion Starter #14
well, the bed didnt come out as good as i hoped,
i leveled the bed, and cut it 90*, but i was in a hurry and didnt spend too much time on it. i had to get it done.
it needs to come back off and finished up, but it dont look too bad as a 5 foot bed
its hard tach'd and will do for now.
Discussion Starter #15 (Edited)
update.
all new fuel system.
Facet e-pump, Bull Moose IP, Mister Mark II injectors
new turbo on its way with a WWII for the 093.
stainless inner cooler piping.
Discussion Starter #16
a year and a half later,
lots of money,
lots of time
and I still havnt finished the bed.
but heres an update....
looks like I goofed up on the title, this is not an 86, its an 87!
Nice work.
Reactions: h0trod
AMERICA!
Fixed the thread title for ya.
Pretty cool build, definitely interested in see it all complete. Keep up the good work.
Discussion Starter #19
im having a hell of a time sealing this block up.
I keep getting water in my oil.
I have isolated it to the timing gear cover.
ive had the engine tore apart several times now, used 3 different types of sealant.
I know for a fact that its the front cover.
how do I know this?
ive made block off plates for the oil cooler and water passages, it holds 20 psi all day long with the oil cooler installed,
20 psi with the front cover off and water ports blocked off.
ive had this engine on the pressure tester for more than 50 hours, turning the crank 90* every couple of hours to rule out cavitation.
ive pressurized each glow plug hole with 120 psi, and no bubbles in my radiator.
for some reason, im still leaking water in my oil.
I have not put coolant in it due to this issue,
ive driven the truck about 100 miles to see 1/2 a gallon dissipate in my radiator.
the valve covers, have signs of water.
today I drained the oil and put the pressure tester on it again, im expecting to see water after the oil is drained.
ive finally located another timing gear cover. 80 bucks on e-bay, I will be trying that next.
there is some pitting on my cover, but it appears to be in good shape.
im at my wits end with this truck honestly.
ive been very tempted to throw a powerstroke in it........
Subscribed! nice build, hope you get her sealed up :thumb:
1 - 20 of 68 Posts
