Did a lot of work to the truck last year including the addition of 190/30 injectors and a custom regulated return woth a fuel bowl delete and with fuel being fed from the rear of the heads. Previously I had installed a 6.4 pump before my HFCM. After I got the truck back together and added a fuel pressure gauge, I saw that I would drop from 60 to 40 psi on a WOT run. Which leads me to this, after comptemplating a custom Fuelab setup I decided to chose the 6.7 pump. Here is the parts list for what I have gathered to build my system. I listed where I picked everything up from as well. My system is going to tie into the custom regulated return I built with 6AN hose. My plan for fuel flow is as follows: Sump- 6.7 pump- Cat fuel filter on frame - "Y" feeding the rear of heads- existing regulated return - back to tank with 1/2 return added to factory sender. I will update as I progress.
1× PFB-103-BC3Z-9G282-E 6.7 pump only (no bracket) (Ebay)
1× BC3Z-9A335-E Bracket for the pump (Ford)
1× WPT-778 3U2Z-14S411-EUAA Pigtail for pump power (Ford)
1× 84-899785K30 Mercury marine relay harness and wiring kit ( from my work)
4× 716-08-08-BLK Speedflow 1/2 efi adaptor fittings 8AN (Ebay)
1× Wix 24770 fuel filter head (Amazon)
1× Cat 1R-0749 fuel filter (Amazon)
2× AER-FBM5008 Aeromotive 1/2 NPT-8AN adaptor (Summit part #)
3× FRA-209008-BL Fragola 90° 8AN fitting (Summit #)
6× FRA-200108-BL Fragola 8AN straight fitting (Summit #)
1× VPE-10432 Vibrant 8AN-6AN reducer (Summit #)
1× VPE- 10807 Vibrant 8AN-6AN "Y" (Summit #)
2 × FRA-871508 15ft Fragola 8AN push lock hose (Summit #)
1× Vulcan 1/2×5ft 8AN fire sleeve (Amazon)
1× EAR 165108 8AN to 1/2 tube adaptor (ANPLUMBING.com)
1× EAR100037 1/2 Aluminum tube 10" (ANPLUMBING.com)
1× EAR992408 8AN bulkhead nut (ANPLUMBING.com)
1× EAR983208 8AN bulkhead fitting (ANPLUMBING.com)
