Hello my name is mike and I'm new to the forum. I just picked up a 95 ford f250 7.3 power stroke, it's am auto 2wd truck. It runs and drives but needs a little work. It has some rust issues, and a fuel leak from the diesel pump under the turbo, and shifts hard between 1st and second gear. The truck is currently stock, but I have bought some parts that I plan to install asap. It also came with a complete 95 f250 7.3 5 speed 4x4 parts truck.
First I bought a rust free cab, front clip, and core support that I plan to paint before I install it onto the truck. First I plan to do the little bit of body work that needs to be done on it, and bedline the underside of the cab, and them painting everything (including jams) before installing it onto the truck.
Performance wise I have picked up a set of 160/30 injectors, air dog 2 lift pump, diamond eye 3" down pipe, 4" exhaust to a single stack kit, glow shift pillar mount gauge pod kit with EGT, Boost, and water temp gauge. I also picked up a snow performance meth injection system. Holding off to install everything due to having plans to order some more stuff before hand so I can just install it all at once. Planning on ordering an irate diesel regulated return fuel system, andrenaline hpop, cold air intake kit, ARP head studs, smith push rods, comp 910-16 valve springs, new valve cover gaskets, harnesses, and glow plug kit, cx racing front mount intercooler kit, riff raff billet intake plenums, and a ts performance 6 position tuner. This is just a start of what I want to do but I figured it's a good start to a solid build.
plans for later would be
300/200 injectors
s366 t4 turbo (or a compound turbo set up)
dual hpop's
dual air dog 2 lift pumps
custom tuning
Zf5 swap with upgrade clutch and flywheel
possible 2wd to 4wd conversion being I have a complete 4x4 5 speed parts truck and and a ts performance 6 position manual trans tuner,
body wise I plan to paint the the truck blue with a black painted front bumper, black billet grille, black housing head light lenses, with LED bulbs, *********** stroke diesel windshield banner, billet antenna, new 7.3 power stroke emblems for fenders, 5% window tint, rain guards, 52" light bar for across the roof, custom flat bed with built in head ache rack, and flush mount LED tail lights, and dual black cat stack's and black 22x12 wheels with 33x12.50r22 tires.
i know it's going to to take me a few years to reach my goal of where I want the truck but it's something I've always wanted, and happy to of finally got my dream truck.
my 1995 ford f250 7.3 power stroke auto 2wd
the 95 ford f250 4x4 5 speed parts truck
300/200 injectors
dual hpop's
custom tuning
