1 - 12 of 12 Posts
Just curious what you guys w/ 37"s and 6" lift are getting for mpgs...
I'll listen to yours before I give you mine....:dunno:
My OBS (I know... totally different) w/ 35's and a 6" gets 18mpg city driving all day long. 15ish mpg towing 5k lbs.
i get around 16 normal driving, with 35s and 4 inch lift, if i can keep my foot out of it
I have a 6in with 35s. I got about 14.4 out of the last few tanks, but that was more city and less highway. The best I ever got was 16.87 mpg all highway from San Francisco down to fresno doing 70mph and the truck bed loaded down with camping gear and 4 other people in the cab. Im running a tank strictly highway so I'll let you know. I'll be getting some humvee 37s for my next set of tires so I'm curious as to what the mpgs will be with them! Hope this helps you a bit
he asked specifically about 37s with a 6 inch lift not 35s with a 6 inch
LT, looking at your sig....our trucks are VERY similar....w/ the ekception of the tire size....TW tuner, 5" straight ekhaust....I am working on getting the 6637 filter soon. I have the K & N and heard many bad things about it....I'm barely getting 10-12 mpgs...and I am rarely over 2k rpms....
What gear ratio do u have? Check for leaks in ur up-pipes. The 6637 will definitely help your truck breathe a whole lot better! Also what tunes do you have on your chip and what do you use the most? I hear with 37s you're suppose to get better highway mileage but lower in town mileage. Right now I'm pretty tired so I'm having trouble thinking of other causes of poor mpg, but I know some other guys will chime in and help out. Theres also quiet a few posts about poor mpgs and thinks to look into. I can't quiet remember what it is but i think the EBPS or EBVS or something tube could be dirty and needs to be cleaned. Someone tell me if I'm wrong please. Its something along those lines lol.
But Sgt as far as in town is considered. If I'm driving mainly in town i average about 12.5mpg no matter how I drive. Flooring it or put-puting like a grandpa. On the highway keep it below 2k RPM. Keep in mind our trucks do weigh about 8k lbs so we wont get phenomenal mileage. but 10 sounds a bit low. Especially if your driving is highway. Gives us some more details on what you have done to your truck and what type of driving you mostly do. Do you tow a lot? All city? Highway? a little more will help us out
Not sure what gears.....I havent done anything to it performance wise other than change the oil...I am mostly "rural" driving....8 miles to work on windy roads.....small runs on the highway between the city and larger town near me....I have a F-350...didnt realize yours was only a 3/4 ton...
I have the TW 6 pos tuner, 5" straight pipe, 20"s wrapped in 37" nitto's....after market waste gate actuator, and the K & N like i said....
my bad...i knew your ride was a 1 ton....the difference was the year....'01-'03....
What does being a 1ton have to do with anything
Discussion Starter #12
nothing. i was correcting a mistake.
1 - 12 of 12 Posts
