Curious as to what the consensus is on why some trucks get better mileage than others. I am guessing its the engine management systems and components rather than the overall truck itself or the basic longblock of the engine. I am looking for everyones thoughts on what they think makes the difference in equally optioned trucks getting varying mileage results.
Say for instance if you change out a bare long block using your current engine managements systems (sensors, injectors, ficm, etc) you should retain the same basic mpgs i would think. Taking into account of course you are replacing an engine due to catastrophic failure that ran fine prior to failure vs replacing an old high mile worn out low compression or dusted engine which has lost its efficiency.
For instance my 03 6.0 dually 2wd crew cab bone stock with 4:10 axle ratio will get 19 hand calculated at 70 mph and 22.5-22.9 hand calculated at 60 mph. These figures are running interstate with no stops between fillups going cross country. I want to do some work to the truck including egr delete 4" exhaust and a tuner. I have recently purchased a gear vendors overdrive since i have 4:10's but havent as of yet installed it. so looking forward to what my end results will be.
