1 - 10 of 10 Posts
I have a 2008 F250 6.4 with the ZF6 transmission and my MPG is the exact opposite of what every other truck I've ever had. In the city I get about 14.5 MPG but on the Highway at 65 MPH it drops to about 11 and even the slightest addition of throttle results in the instant MPG dropping to 5 - 7 MPG. All these MPG are with the truck unloaded and it has 3.73 diiff.
BBBRRRRRTTTTT
lie meter or hand calculated?
whats installed on the truck? sounds like you have something that really drags the truck down at higher speeds, like a camper or big bumper...
Administrator
The meter means nothing, hand calculated is the only way to accurately measure your fuel mileage.
Well that is the opposite of what it should be...even by the lie-o-meter. Ever since I deleted, the lie-o-meter says I get 23mpg...yeah right, closer to 17mpg. Hand calculate for sure to see what you're really getting.
Administrator
its not opposite if he is looking at the real time mpgs on a tuner and hitting the throttle.
it will blow his mind when it drops to zero pulling a hill.
how are you calculating the difference in MPGs?
Usually the way it works out is I end up doing almost all city driving, or driving long distance on the highway. When I fill up I just divide Miles driven by gallons on fill up. After multiple fill ups it keeps coming out the same.
1 - 10 of 10 Posts
