1 - 16 of 16 Posts
My Lariat had one, do the XLT's have them? I test drove an 05 Lariat today and it was above the odometer.
they have them but dont rely on them as they are inaccurate as hell especially if yuo run bigger tires. just do it the old fashioned way.gal/miles
Where they do work well is to give you an idea on what kinda MPG's you are getting at certain speeds. Not as an overall average....
My 04 KR has one and its way off. I am runing larger than stock tires. And it seems to be stuck in the high 13's low14's. And with every xx.1, xx.2 exc. seems to correlate to 1 real hand calculated mpg. when I'm at 14.3 on the comp. I'm running 16mpg. Kind of od but o'well.
they can be recalibrated for diferent tire sizes i have been told.
i recalibrated mine with the pda but it doesnt affect the factory gauges the speedo is off 2-4 mph it just tells you on the mph parameter on the pda itself. so im not sure you might be able to take it to ford but i dont think that would be worth the trouble..
if you recaled i would have thought everything would be adjusted. Humm...sounds like a question for Ford
The recal on a tuner is strictly for tranny shift points. Ford will usually reset the speedo for free if you know your service writer. Or most truck/offroad shops have a box to do it for pretty cheap. Luckily, my built in meter is usually within .5mpg of my hand calculations.
???? possibly im not sure i now the pda displays the correct speed becasue i also have a gps unit in my truck and the pda speed is the same as the gps so i know that one is right its just the factory speedo is still off but im not really that worried about it. im sure it would be right on if i was to take it in and get it recalibrated by ford but its not that big of a deal to me. i dont think even back when my truck was stock the MPG indicator was on the money by any means
thats cool, the only thing i have heard about fords mpg unit it is on all the time whether you are driving or just sitting there at a stop sign. i have heard the GM and DODGE units stop when yuo stop and idle and then once your up and running again they will kick back on???
The idiot meter in my truck seems to run pretty close. Though I'm interested in the d-max meter now. If they aren't counting fuel consumed at idle that would explain alot about the extra mpg's my buddies d-max seems to get around town.
:icon_ford:
What causes the meter to recalculate or change?
I know that if I want to reset the device, it can be done manually. It then does some type of instantaneous calculation and displays the current MPG. If you reset while accelerating, it's a low number. If you reset while coasting, it's a high number.
Does anyone know if the device actually keeps some type of accumulation and becomes more accurate as miles go by?
The number it shows is an average of recorded mileage at intervals. It just keeps averaging from the numbers it gets.
mine seems to update every 5 seconds or so.
1 - 16 of 16 Posts
