1 - 5 of 5 Posts
Ok, motor will crank but not turn over. I hear the fuel pump and I have fuel pressure. I just repaired my ficm (did not replace) still will not turn over. Here is what the ficm looked like. What else can I check?
774266
774267
Ok, motor will crank but not turn over. I hear the fuel pump and I have fuel pressure. I just repaired my ficm (did not replace) still will not turn over. Here is what the ficm looked like. What else can I check? View attachment 774266 View attachment 774267
Do you have FICM Sync? Has anyone validated your FICM is on working order? That would a starting point baseline— before attacking anything else. I think Ed at FICMREPAIR only charges $75 for the FICM test... Might be worth it in my opinion— otherwise chasing ghosts on this engine is EXPENSIVE without a code scanner... Beat of luck 🙏🙏
+1 to get a good scan tool - ForScan is recommended.
What ever did that damage to the FICM probably caused other unwanted things to happen also.
thanks, I need to get a scanner to read my numbers
Yeah.... Willing to bet the logic side is cooked too.
But, as we all want to do...ignore the obvious
1 - 5 of 5 Posts
