A month or two ago I posted about low idle acceleration problems and it was recommended I check my batteries and ficm. Went to the mechanic and of course problem was gine, but had everything checked and was fine. Ficm voltage at 48, battery load test good, all injectors working fine, fuel pressure at idle was 65 if I remember correctly.
This morning after going to the gym, the truck wouldnt start. After a couple of minutes it started but very erratic, but managed to get to work. On the way home luckily already on my street there was no response from the pedal at all but the truck was still running. Could this be a fuel pump issue? The oil and fuel filters were changed 4000 miles before, but im going to check the filters now. Any suggestions?
Sent from my SGH-T959 using AutoGuide.Com Free App
