1 - 5 of 5 Posts
Hey guys im running 155cc and a 64mm non vgt i was thinking of upgrading to 180cc what else would you recommend doing at this level?
You may want to start saving for a tranny. Depending on how you run her, you could be above what the tranny can hold. I know quite a few people that have started smoking things when they got above 500hp.
Outside of that, looks like you have the fueling, requirement for 180's
Turbo can handle it pretty well
How is your spool time and daily driving with the 64mm compared to the vgt? Do you throw more smoke down low with it? How is your highway cruising with the 64mm? Can you current inj spool this turbo.
its a bit slower not much tho I like it seems to pull harder up top. yeah there quite a bit more smoke now down low just have to roll on to it instead of just hammering it. i can keep it at 5psi while driving down the road. 155cc are lots to spool it. but im thinking some 180cc will work quite nicely
1 - 5 of 5 Posts
