1 - 19 of 19 Posts
I live in Minnesota and have no need to leave the state, with the 41k load
So I have a telehandler that weighs approx 25500 lbs (the machines plate only says 23400 pounds but the tires are filled with 500lbs of foam per tire), and I haul it about 1-2 times a month, 5-30 miles per trip. I carry this on my 06 f250 srw +03 delta tandem duel goose neck (gvwr 23400).
I have scaled the combination at 41k lbs pickup,trailer,and tele handler.
I have scaled the pickup and trailer at 15500, And have scaled the pickup at 7800 lbs? (if my memory serves me right) its an extended cab single rear wheel.
Right now I am stumped on a decision mainly because I don't know exactly what Is legal.
Could I buy a different trailer for my pickup like a gooseneck triple axle with duels (gvwr36k) would I legally be able to haul it with my f250?
Also looking at possible getting an f550 or maybe just getting a tractor trailer combo with a stepdeck/lowboy
What are your axle weights? Might be able to get by with adding an extra axle to your trailer if the pin weight is low enough. Best bet of what I would do is pick up a big truck and pintle hitch trailer for that. Buddy just got a great deal on one for 9500 that is turn key ready to go and nice. Makes dragging around equipment much safer and less stressful.
Brett
I live in nw Iowa and haul almost identical to you and haul into Minnesota a lot with about the same setup well used to I should say. Mn dot even stopped me with the load and have me a quick inspection and sent me on my way. I did what they want us to do in Iowa which is up my registration to 20 tons and had to get my cdl class a . I ended up finally going back to a dual rear wheel for safer feeling. My setup now is my 2011 f350 and I have a 53' flatbed gooseneck that is rated for 26,000. You should be fine but I would recommend a dually just for stability. A lot of guys don't like to see that behind a pickup but I made a trip from Iowa to Columbus ohio picked up a telehandler,platform,bucket,forks,and a rafter boom drove back hit all the scales and never once did I get fined or shutdown. Only thing I've been getting fined for lately is window tint and I didn't have my dot numbers on right away. Also they are starting to get pretty picky on the amount of chains and straps u have on everything. For instance on a telehandler a dot told me minimum five chains . 4 on machine in the four corners and one over the forks or boom. Everything else on trailer needs two per item and if they are straps no straps on the outside of trailer and always have the ratchets to the passenger side
Dougs right there is no legal way you can haul that with your current truck and trailer setup
CDL time
Thanks for the replies, skinny how many miles would you say you carry your telehandler in Mn? I always hear Iowa Is alot stricter with dot regulations but Im sure each person picks at differn't things, as for a pintle hitch trailers, I don't like the look of pintles on pickups people say they are stronger but I would get a tractor for pulling a pintle trailer then I would already be set up for the air brakes.
As for the tractor trailer comment I'm young(21) so I'm gun shy about spending 5 grand on a truck 15k on a trailer and 1k annually to licence a tractor trailer rig.
Lastly I've had my class A +endorsments since I was 18 but I would not need a cdl in Mn even if i was grossing 80,000 lbs Since I wouldn't be "for hire" just hauling my own personal property.
I've gone all the way from home (Sheldon Iowa) to Minneapolis with my crew cab 2500 srw and usually I'm about 60 miles or so into mn and all over Iowa and like I stated earlier always stop at the scales and never have any issues. I don't pull with a pintle hitch either never cared for them. My telehandler is a ingersoll rand vr42c and weighs at 24500 . My main reason for going drw was for stability and also cause I'm constantly pulling 18k plus and that is too much for a srw all the time IMHO . Iowa dot is very strict to although now empty I have to pull into scales in sd and mn lol blew by one a while back and they made me turn around to prove a point I guess lol.
Mod Newbie
You do have to have a CDL for anything over 26k lbs. What you so is buy a small tractor and set up an big goose neck that is rated for what you need to haul and start that way. Trust me, the money spent will be far less painful and troublesome than getting popped by DOT, even once. You have any kind of wreck with the setup you have now, you'll be screwed for a long time.
Correct on the cdl I was told during my annual inspection if the pulling rig is a gvwr of 10,001 or higher cdl required even if it's not for hire also of your combined gvwr (not actual weight ) is 26,001 or more cdl required. They are actually starting to pull people with campers over now to check registration and licenses now and I have a friend who got a ticket because his registration wasn't up to par. State of Iowa registers trucks for 3 ton and it's up to the owner to know to raise that kinda crappy on their part for not telling the public but I guess it's their way of getting revenue
If I was to get a tractor/trailer setup I would go for the full 80k to move my tele, sizzor lift and skidloader in 1 load. Not to mention I could hopefully pick up odd haul jobs here and there. All probably intrastate
I would cause telehandler 24,000 scissor lift 10,000 skid loader 4500 so that on weight is 38,500 and are u gonna bring your attachments too?? If your like me also I haul a lot of my own supplies too ( metal buildings) and it's nice to have the ability . I've looked into a full rig also and may be going that way for the heavy hauls and time I could save. Another bonus would be winter months if ya get slow you could haul loads
Discussion Starter #12
I've never stopped at the weigh stations between worthington and souixfalls but everytime I notice they are open I'm empty so I don't bother stopping
I tried blowing it and that's when I got stopped lol they warned me last time I stopped because I had one of my tiltbed bumper pulls and the break away cable was hooked with my safety chains so they let me go but said they have to be completely separate oops!! Oh well where ya at in Minnesota and what type construction ya do ?
Discussion Starter #14
Alot of Winkler "hoop"/prefab buildings along with pole barn machine sheds I live 25 miles East of Pipestone, then a bunch of cattle floors, I spent a week working down near rock rapids Iowa last year Love your fuel prices. What do you think of your tilt/bumper pull? My old man wants to get one, and I kinda like the idea, but we have a 14k and 24k goose and our jlg 3394 rt aint gonna fit on a tilt :(, Maybe easy to load when it's a little sticky out?
I like it but my jlg33rts won't fit I have to use a deck over for it. And it pulls like **** empty lol bounces ya all over the place mine is 28' has 24' tilt and 4' stationary. Also got a 53' gooseneck and a 30' triple axle for those pieces and have a 40' fifth wheel enclosed for other things . And yeah our fuel is at 3.79 right now kinda high I think when I can drive to Sioux city and get it almost .08 cheaper lol. I looked at getting into hoop buildings to but got enough going on with the metal ones
Discussion Starter #16
Im supprised 53 ft is legal there I know 53 is legal for class 8 trucks but for pickups in MN i think its less. Mind If I ask how much your 40ft enclosed costed ya? If i got a semi I would probably Modify a dry van into a lowboy dry van. or just mounting van bodies on an existing low profile trailer
Well it's 53' from gooseneck to tail sorry didn't explain that and yeah I got my enclosed off an auction for dirt cheap lol only paid 5200 for it hahaha it was an auction on a farm place and only a couple of us bid on it . Priced one new and it was 14,500 so I'd say I got a good deal
Discussion Starter #18
I think our 14ft enclosed was 4200 i think I wish I paid more attention to detail when we got it really only 2 things I dont like about it. It's too damn small, and the wall plywood is like 1/8 inch, I don't even dare to mount anything on it. Oh and the ramp door was a mistake.
Hoop if you like the winker hoops you should check out diamond shelters. I built them for years
1 - 19 of 19 Posts
