I found a source of dried and filtered (2 micron) wvo for $2 a gallon. Has anybody tried running it just mixed with diesel and not heated, and if you have at what percentages?
People blend fuels all the time. DSE (not recommended) uses Kerosen or diesel to thin the WVO, along with some not so cool chemicals.
Make sure it's clean oil and then start mixing in small batches. Use an anti gel, and make sure your mix is thin enough to not need heating.
Check out the Info-Pop Solvent Thinnning forum. A lot of us discussing it there. I've been doing it for over two years in two vehicles with good results.
