My truck, 99 F-250 SD 7.3 PSD, has been doing this surging/misfire since I bought it in October of last year. It only does it when i'm at a steady speed going down the road. It tends to get a little worse when I come to a slight grade also but if I give it more fuel or back out of it a little it goes away. I also have a superchips programmer and the higher that I put the settings the worse it gets. Other than this issue the truck seems to run great and has plenty of power for whatever I want to do with it. There is no check engine light or codes stored in the computer. I did a buzz test, with a scanner at my work, and they all sounded normal. I also tried to do a cyl contribution test but for some reason it wouldn't do it.:dunno: Wondering if anyone has ever run into this before or might have an idea on where I should be looking. I was thinking of getting a fuel pressure gauge and watching that going down the road..What is a normal fuel pressure reading for a truck like ours.. Thanks
