1 - 2 of 2 Posts
k i just got my new l.e.d. mirrors from the 04-07s and need to know how to wire them. is there any way i can splice into the headlight switch for the running lights and splice into the turn signal switch for the blinkers??
u should be able to. you should have 3 wires coming out of that mirror
one should be a positive/ will be a brown(+) wire behind the headlight switch
one should be a negative/ take this and just ground to the door itself
and one should be a switch wire for the turn signal/ umm this one im gonna have to look for. (should be a negative trigger wire off the turnsignal switch or relay which ever one is more convienent) i would go off the relay but i can check and get back too you.
umm if the 04-07 use a positive pulse turnsignal wire then u go positive insted of negative.
the only problem i can think of you might have it it pulling too many amps and blowing the fuses in that case youll have to wire in relays to boost the power to the mirrors
1 - 2 of 2 Posts
