1 - 8 of 8 Posts
So after about a thousand flawless miles with the mini max, I had a little issue tonight. I had just clicked it up into hot and gave the neighbors a show, and after I got up to speed with my foot off the throttle, I proceeded to dial it back to the no power setting. In the process of clicking it from hot to no power the speedo gauge started bouncing and I got a in dash traction control light it beeped multiple times as the message center for lack of better term kinda freaked out bouncing between normal and a traction control code . As the truck was dinging and flashing at me the only thing I thought to do, ( for better or worse) I disconnected the mini max at the obd port. The dash went back to normal and the truck drove fine but it will not establish communication with the truck any more. I have tried repeatedly to power it off, shut the truck down, unplug, replug and every combination in between but still no dice. Truck runs and drives fine with no lights, I'm just not sure if I'm in hot or wild at this point?
Where do I go from here?
FYI
2011 job 2 f-350 28,000miles
most likely a hardware issue with the OBD-II block or the HDMI cable. If you have another HDMI cable at the house, you can swap it in and see if that's the issue. If it doesn't cure it, call H&S Monday morning. They'll get you fixed up!
Easy fix, after robbing a hdmi cable from my home theater system, I grabbed the mini max from its cradle and discovered that it came unplugged from the hdmi from the back of the mini max.
Thanks for the help.
Great to hear that! Good luck.
FYI
Glad to hear its fixed now.
But just a fyi when you unplug your mini from the obd port. It automatically turns power back to no power. :thumb:
Sent from my DROID RAZR using AutoGuide.Com Free App
Discussion Starter · #7 ·
Huh, didn't know that:thumb:
1 - 8 of 8 Posts
