1 - 5 of 5 Posts
hi i have a 97 f250 and the oil is milky and have been told different things from different people like it could be the head gasket or the injector o'rings or the oil cooler any idea would be a big help
thanks
HardLuck Case of the Year
Headgasket go boom and coolent got into the cylinders.
thanks
If it runs ok & there isn't bunch of steam coming from the exaust , the oil cooler may be a good place to start, alot less work.... Do you have a way to pressurize the system?...A head gasket will usually over pressurize & blow coolant out of the fill opening....
Have you been needing to add coolant?....
i have had to add coolant and there is no steam out of the exhaust, thanks I'll put off the cooler and get it checked a hell of alot easier.
had the cooler checked came back ok so i pulled the heads off and found a split bore, so now i have to buy another engine, i have located a 00' 7.3 but don't if it will work in mine or is it a differant set up ?
1 - 5 of 5 Posts
