1 - 11 of 11 Posts
Hello Everyone,
Today while doing an oil change I found a piece of metal attached to the magnetic drain plug. Does anyone have an idea what this is or where it came from? The truck is a 2005 f350 with around 146,000 miles on it. thanks in advance for the help!
Looks like part of a tool someone dropped
what is that clip on the end supposed to hold?
like a driver or magnet?
Almost looks like the end off a control rod, where the ball joint connects
but there is not anything like that inside the engine
is that a bit of rubber inside the end opposite the clip?
tip off the glow plug connector harness?
that is the part of the terminal that slips over the glow plug connection
Here ya go
1 - 11 of 11 Posts
