My message center switches between front door ajar and rear door ajar when I only have the front door ajar. I have the amp Powersteps and have been having problems with the passenger side step not going up all the time. So I was messing with opening the doors and when I open the passenger front door I noticed the message center display switches between front door ajar and rear door ajar. I close the front door and open just the passenger rear door and message center says the same thing. It switches between front door ajar and rear door ajar. I'm positive if I can solve this problem it will also fix my powerstep problem. Any ideas??? All wiring looks correct in passenger sill for Powersteps. I have never had a problem with driver side steps. Does this only on passenger side.
Thank You in advance!
