1 - 20 of 59 Posts
So, I decided I am going to do the manly thing and change my oil this weekend.
Problem is, I've never done it, so me needs a little guidance. I search for a bit on this topic, but did find nuttin. I didn't look hard either.
So, first question, where do I drain it? Is it the nut on the bottom of the oil pan? Or what I think is the oil pan. Big and black thing on the bottom of the engine.
Second, where the hell is the oil filter? Is it the one next to the fuel filter? I changed my fuel filter a bit ago, so know where that's at.
I know this is stupid, but I need help.
BTW, I paid $22.24 for a Motorcraft oil filter. Is that good or bad?
Damn I sound like a noob now.
LMAO
LMAO
The oil filter is the black cap next to the fuel filter. You can use the same socket to get it off as you did the fuel filter (36mm, I think). Loosen the filter cap and let the oil drain into the oil pan.
Then drain the pan with the nut at the bottom. It will hold about 17 quarts, so have a big enough drain pan.
What you paid for a motocraft filter is not too bad. I prefer the Wix filter personally. It is a little taller (more filter media and volume), and it comes with a new filter cap. It is also constructed a little better. And it runs about a buck or two more than a motocraft filter.
Damn noobs!!! :D Well it's about time, Mark. I am much happier knowing that I changed my oil and that it was done correctly.
is this your first oil change ever?
i would image its the same on the 6.0. simple, easy.
btw not sure on the part number for the 6.4 but walmart sells motorcraft filters for the 6.0 and 7.3 there. for the 6.0 part # FL2016 for $16.XX
Remembers, those there engines holds alot of that there oil so makes darns sure you usees a big enuff bucket or you wills have oil all over the drive ways. I usees a 5 gal pale, fits perfectly under that there power plant.
Why is I's talkins like this?
Thank you very much. That's about how I thought it was going to go, but I wanted to make sure.
Seriously, those noobs are hell on the ORG. Posting stupid crap that's already discussed and stuff.
I will feel better doing myself, but the money savings is a big plus. That's what pushed me to do the fuel filters. I couldn't swallow a $186 for that.
First ever doing it myself. Jolene has had a few lube jobs before, but this time it's my turn do it. I don't like other people touching my woman anyway.
I wanna go fast!
The 6.0L oil filter is the same for the 6.4L
I wanna go fast!
Id be careful with those, ive got several friends who have painted their driveways and mine black bc the pan wouldnt vent fast enough and started flowing over!
Mine has overflowed before, but not because of capacity. That's the same as the drain pan I have, but it drains from the truck faster than it can go in the little hole... :doh: Installing a fumoto valve allowed it to slow down the drain from the truck just enough to eliminate this problem. :thumb:
Discussion Starter #12
I just read all the reviews on it. They don't speak too highly of this thing.
But will a 5 gallon bucket fit under the truck without jacking it up?
Discussion Starter #13
LOoks like I better put a slip n slide in the front yard while I'm at it. By the sounds of it I am going to have oil all over God and creation.
BTW, after I change the oil, I am gonna do the harpoon mod. How much beer should I have on standby for this event?
Should the neighborhood watch and fire department be notified?
I have an older truck and yes a 5 gallon bucket fits under mine.
Discussion Starter #15
Hmmm... I likes da sound of that. Though my truck is stock height. Will have to find out later today.
yeah im sure it will if not. Flex your truck on one of ur front tires and it will fit under:thumb:
I can get a 5 gallon bucket under the pan, but once its full, its going to stay under the truck unless you dont' have running boards :dunno:
Mark, do yourself a favor and try and get a Fumoto valve before changing the oil. It will replace the drain plug, and let future oil changes use less rags, and keep the oil in the drain pan. I've sprayed me and my drive down with oil, and the diesel oil WILL stay on your hands for a while, unless you use some brake cleaner or something :nod:. I wear gloves now, I know :supergay: but the wife won't let me touch her with the black stuff in all the cracks in my hands :wink[3]:
Discussion Starter #18
I've got me a set of chrome step bars, you know the ones from Ford.
I will think of something.
Meanwhile, if any of y'all have any creative ideas, please let me know. I plan on doing this tomorrow morning.
Just run one of ur front tires on a board or something and it will flex... it will fit then
I just use a big green oil drain pan that I got from Walmart. That holds all of it. And I agree with the Fumoto valve. That makes life a lot easier!!
1 - 20 of 59 Posts
