Quick Question for the board:
Assuming Coolant temperature/boiling is not an issue, what is the maximum safe EOT for our engine? Assume it's just sitting there at idle speed, getting hot. No extreme load, no turbo spool no high rpm's. Just sitting there, in a driveway, idling, with the radiator fan unplugged so as to intentionally allow it to heat up.
The reason I'm asking, is I'm trying to get as much water out of my coolant system (waterless) as possible before this trip I'm going on. The Coolant doesn't boil until 370 degrees Fahrenheit, and in fact, the recommended way to get all the water out as soon as possible is to heat the engine up to about 280, and let it boil out. (see page 5 here if you don't believe me: http://www.hrpworld.com/client_images/ecommerce/client_39/cat_header/683_4.pdf) You may think that it is for RaceCar use only, as that is the main site, but that document specifically mentions powerstrokes. I don't think that 280 is a safe number at all, but getting my coolant up to 230 or 240 shouldn't be a problem. The only issue I see, is it will also get the EOT up to about that hot.
Anyways, My ECT's don't hardly ever surpass 200-210 degrees under normal operation, so it will take a long time for the water to boil out on it's own it seems, and I want to get it out of there ASAP, for a few different reasons. Chances are that it's already pretty much all gone, I just want to be sure, but I don't want to run it at 230-240 degrees if there's any chance of it causing any problems.
So, summation: Assuming no load on the engine, idle speed, what is the maximum safe EOT that can be reached without any harm to the system if I am intentionally raising the engine temperature for another purpose.
Edit: I have read elsewhere that the engine begins to Defuel at about 250 degrees. I'm assuming then that that means that is the point at which Ford believes there is a problem. I have also read elsewhere that people have seen 240 degrees during legitimate towing operation, and had no problems. So perhaps keeping it around 240 would be okay for this exercise?
