2000 F350 Diesel Crew Cab, Long Bed, 4wd
What would it take to make a 1 ton out of my F-250? :dunno:
Is the rear axle the same as in the F-350's other then the dually wheel set-up? And how do you convert to the dually wheel set-up?
Is it even feasible and worth the conversion financially (I'm not talking about someone with an endless budget here!:doh:)
International Threat
Start by getting the rear axle, springs, rear driveshaft and hangers/shackles from a dually and go from there!
99% certain that the axle is the same, just the suspension is different on the rear end. the front end is usually different. just a matter of buy, bolt up, and then drive off.
