1 - 5 of 5 Posts
I was reading through some posts on here and it said that the muffler is louvered inside and depending on how it is installed can determine the sound.
I had the shop install it so I'm not sure which way it is installed. I would like it to flow with the louvers, not against them.
Is there a way to tell how it's installed without dropping it to look inside?
When I crawl underneath from the passenger side I can read "Magnaflow".
The "Magna" part is closest to the engine while the "flow" part is closest to the tip at the back.
Thanks...
So there's no difference either way it's installed?
same same.....
Right on.....Thanks for the confirmation.
I think I'll leave it alone. Sounds like it's installed right.
1 - 5 of 5 Posts
