This one finally showed up so now I can test it. Fit an finish is great which is normal for Magnaflow stuff. I'm testing the 60111 "49 state legal" CAT in 4" in/out. First I tested the 60011 "offroad" CAT 4" in/out and over all it was great. Here is the Link to that thread. I wanted to try this one for several reasons. First to see if it would control noise a little more over the 60011 which it did but the turbo whistle of the pmax is still very noticeable but with the edge taken off a little more. Second was the smell, virtually gone although the tail pipe heat is much more noticeable. With the 60011 offroad CAT or non CAT the tail pipe heat seemed to be the same. Also now at least I have something 49 state legal that I can swap between offroad and legal within 15mins. It didn't change EGT's at cruise or WOT at all. EBP pre turbo seems to be same as before also but I want to get more drive time on this but I don't thing it changed cruise or WOT. Anyways here are some pictures.
Edit: I just wanted to add that this testing is done with Id's non-inductive performance FICM tune, ID's custom ECM stock power, EGR disabled, Pmax tune in VXCF9NZ
