1 - 8 of 8 Posts
PMR = JUNK
How do i tell if i have a limited slip differential, the sticker in the door jamb has nothing under the axle code.
you can look on the back of your diff and there will be a little tag that will say if it is or not. ill get a pic and show you...
PMR = JUNK
what year, model, etc is your truck....
All in the sig:thumb:
Most likely it is a LS......did it ever spin both rear tires at the same time?
It spins posi usually, however my old truck and my grocery gitter i still have will spin posi sometimes.
PMR = JUNK
2000 F-250 4X4 Ex. Cab
7.3L PSD, 4R100 Trans
PMR = JUNK
I use the option,...to turn "sig's " off,...they are an annoying amount of info...
spinning posi,..isn't a positive way to tell if it's a LS,...but it helps...
Yeah, my old truck and grocery gitter have open diffs.
1 - 8 of 8 Posts
