noticed something went through the low pressure side rings and mangled up some of the surfaces pretty bad. inner and outer pump rings will be replaced should I change the entire front cover as well?
there is a nail catching scratch on the upper part of the rear of the pump housing circled in red. the pump housing cover behind drive pulley is good there are marks but they can not even be felt with my nail.
This engine was making good low side oil pressure and running before i took it apart so im wondering if i can just change the pump rings and not go looking for a new engine front cover
