Hi Guys,
sorry for the long read it’s been a sh** show.
Truck: F550 6.0
Mileage:92xxx
Year: 2006
a little Over a month ago I took my truck to the Ford stealer for a oil change the next day it fired up got to my job 17 miles away and has been cranking no start since.
I took it to the dealer, originally we thought it was an stc fitting leak they never found a leak after several pressure tests with and with out valve covers
we than replaced the ipr
than checked for a leak again tried searching for blockage took apart dummy plugs and fuel rails no luck or blockage found
we than replaced the hpop
I come to find out after a month of working on it at the dealership and thousands in parts and labor I find out that they broke the oil filter housing tube during the oil change. which I know is directly related to oil pressure after fighting the dealership over this they have buttoned my truck up and it’s sitting at home now.
ficm Sync is in spec
Ficm main power is great at 47+ when cranking
Ipr% reads 84.7 (yikes)
Icpv reads .24
Icp pressure reads 370 Max when cranking
a leak has been ruled out over the course of many back to back checks with and with out valve covers with shop air
everything I could throw at this I have thrown at this with the exception of the oil screen beneath the oil cooler.
Am I missing anything? What else can I check?
Truck: F550 6.0
Mileage:92xxx
Year: 2006
Icpv reads .24
