1 - 2 of 2 Posts
I was going to post this in the 7.3 area but decided to post it in the General area for more people to see and help me troubleshoot. I have an '02 F-350 LB,CC,4X4. It has an Edge Evo 2, Magnaflow Turbo back exhaust, AFR cold air intake, Adrenaline HPOP, 6.0 IC and a Boost Annihilator. I have never had any trouble with this combo and my EGT's have never reached over 1000 degrees on my gauge. Last Saturday I was coming up a 7% grade that is approx 3 miles long. I have pulled this grade a million times and never seen anything over 900 degrees. On this particular day I was doing about 85 MPH and noticed 3 things all at once- I was blowing more soot than usual, My EGT's were at 1200 degrees, and I was only putting out 12-14 pounds of boost. I usually put out 25-27 pounds with the boost annihilator in place. After that the EGT's go right up to 1000 if you stuff your foot in it. Flat out, no hill, no nothing. I have pulled the turbo off to look at it and I can't find anything wrong with it. No shaft endplay, wastegate appears to be functioning as does the EBPV. I am at a loss. Anyone have any ideas? Even the smallest suggestions would be appreciated.
Thanks, Darin
check your uppipes, if theres soot on your firewall theres your prob. Also check your IC boots, closely!
1 - 2 of 2 Posts
