check your oil cooler on driverside of engine you can see it from the driverside wheel well it the only oil can get into your coolent your coolent can go in the oil if the cooler is bad as well.
The oil cooler on a 6.0 is mounted under the oil filter houseing in a cavity in the valley between the heads. It is not externally visible. The oil cooler on a 7.3 is external and can be seen from the drivers wheel well mounted on the side the block.
Either way you have an oil cooler problem.
ruptured oil cooler. Time to delete the EGR and rebuild the oil cooler and flush the cooling system.
