1 - 12 of 12 Posts
What causes a lope on start? 97 F350 that's been converted to a manual. Does it anywhere from 3-6 seconds no matter warm or cold, I blip the throttle after it fires and it smooths out? I plan on going to a lighter oil but want to make sure nothing else is causing it.
On the OBS trucks it takes a few seconds for the mechanical fuel pump to build full pressure causing it to lope on startup.
I will double check on the pcm, I am not 100% sure if it was re flashed. I'm puzzled because our 2 other 7.3s don't do it, one is Efuel and the other is the stock pump but both are auto.
I confirmed the PCM is the correct one for the manual tranny, now onto the next possibility, the truck has 170K miles on it.
I know it's been a few days since you posted. Do you have an engine heater? If so plug it in for a solid 4-8 hours depending on the outside temps. Go ahead & fire it up to see if your loping is still an issue or if there is any change at all.
Sorry for not responding, turns out the pcm was still the auto one, got tunes from php and it has since corrected it, runs great now.
I figured as much. You had the typical signs of running an auto tune with manual trans.
When you originally responded back saying it had a manual PCM, what method did you use to confirm this? Just curious.
Discussion Starter #12
i called shop i bought it from, who said it originally came to them already converted. they then converted it from a zf5 to a zf6.
1 - 12 of 12 Posts
