1 - 5 of 5 Posts
im wondering if theres any way to tighten the latches on the ext cab doors, theyre rattling a bit going down the road and its getting annoying!
Do u ever lube those latches?? I lube mine regularly. U also might consider doing the door seal mod.
door seal mod? i havent heard of that
Change out your hinge pins, (available from almost any auto parts store) then adjust your striker bolts to get proper tension. Takes about twenty minutes per door.
I have the same problem, let me know if you find a good fix. I did the door seal mod, and only seemed to make the rattle worse. Good luck.
1 - 5 of 5 Posts
