I have a truck in that I was told died and would not restart. When it was dropped off I cranked on it a long time and once the oil pressure gauge came up it started. It takes a long time for icp to build when cranking but once it does it starts. It seems to have oil in the reservoir for the hpop. Took the oil pressure switch out and oil is down about 1/2 inch from the top after sitting overnight. Also took the check valve out and everything looks fine. Pulled the ipr to check it and ended up replacing it but no change. I cranked on a good running truck yesterday morning cold and the base oil pressure gauge took a long time to come up also. I originally thought I had an issue with base oil pressure but thinking that is not the issue. Am I checking correctly to verify the hpop reservoir is full? If it is full should it at least start and die regardless of base oil pressure?
Thanks for any input.
