truck will sometimes completley shut off or lights will flicker and dim and shut off and cut back on real quick. what the hell iis goin on?
Check system voltage.
check the ground on the bottom front of the engine.. sometimes they will work there way loose and mess up
ok will do what should the voltage be runnin?
runnin bout 14v at idle. where is the ground wire at
Check the main battery positive connection on the driver side battery. The red cable that connects to it secured by a 10mm nut is the main power distribution feed to the everything inside the cab of the truck.
