Firefighter Member
Just out of question....a excursion lift will work fine on a f250? Both 4wd and front leafs.....:dunno:
Thanks in advace
Scott
only differances in 99-04 models is some of the early 99 trucks have differnet trac bar brackets and some minor differances... if the trucks not a 99 then should work no probem, if the truck is 99 check upper trac bar and brackets, see if they are the same
those years should work great
