On a 95 7.3 how do you know you have your banjo bolt in right when you install a new lift pump?
That is correct, as the inside of the banjo fitting is recessed to alow the fuel to pass by regaurdless of were the banjo bolt ends up after being tight.But the bolt has to holes on the sides for fuel flow. So that doesn't matter as long as the bolt is tight?
