What would you do? I'm on the fence between leveling my truck out or doing a 4.5" Rough Country lift. Tires and wheels would be 18s and 35s. If ya got pictures that'd be great too. :thumb:
Yep, I had a rough country 4.5 in my Dodge and it rode like a shopping cart :crazy:If you want a ride that will beat your guts out, get a rough country lift. Save the money for the 4.5" and get an ICON 2.5" levelling kit for around 1G. Budday just installed one on his 05 and DAMN, she rides sooooo nice now. Handles like a completely different truck, and offroad it is a great improvement over stock, front flex is WAY better.
Headlights are adjustable up/down left/right.I know I'm probably beating a dead horse, but doesn't the leveling kit cause you some headlight problems when you're towing? That's the only reason I don't want to do the leveling kit...
Yeah... I know. If you adjust the headlights so that are "right" for driving without a load, aren't they pointing at the sky when you have a trailer behind you? The same thing happens to a truck without the kit, but the effect isn't as bad because the rear end sits higher so the front end doesn't move as much when you put the load on.Headlights are adjustable up/down left/right.
I just don't think the difference in light pointing would change between stock & level. I mean no matter how high or low the front end sits; if a load on the rear of a stock truck changes the headlights pointing angle 15* I don't think it'll suddenly change 20* because the front sits 2"s higer.Yeah... I know. If you adjust the headlights so that are "right" for driving without a load, aren't they pointing at the sky when you have a trailer behind you? The same thing happens to a truck without the kit, but the effect isn't as bad because the rear end sits higher so the front end doesn't move as much when you put the load on.
Agreed, bought mine with a leveling kit already on it, the 285s (33"s) honestly look small. Though since I'm leaf sprung I'm not sure if 35s would rub the springs........Though now that I've typed that it sounds kinda stupid, it's not like guys change the spring spacing with 38"s or bigger.MasterOfTheHat said:I'm just asking... I think the trucks look amazing with no more than a leveling kit.
Which kit is this?go leveled with 35'' i have a rough country leveling and it rides very well. no rub with the tires either
I believe that it is the coil spring kit.Which kit is this?
I am hoping for the exact same look.
