Life Expectancy of a Reman HPOP
4407 Views 28 Replies 6 Participants Last post by  apseagle
2
2007 International VT365
4 years ago I had a HPOP replaced. Couple of weeks ago I had taken the truck in for issues I was having with engine light coming on and engine dying at low speed/RPM. I also was having issues with hard restart when warm. Instead of me trying to explain everything, I'm attaching the repair orders from 4 yrs ago and the other recent one. This last time in the shop, what it comes down to is they (the shop) is telling me I need another HPOP. Shouldnt they last longer than 4 yrs, even a reman?
Font Material property Paper Number Document
Font Paper History Document Commemorative plaque
Thanks in advance for input.
See less See more
1 - 20 of 29 Posts
That all depends on who is doing the reman work, even for the less prone to fail 2005+ HPOP.
No different than starters, alternators, brake calipers .......
Reactions: 5
I am doing a rebuild on my new to me F250 now and am in the same situation. I want to replace the HPOP since mine has 180k on it but all I can find is either rebuilds or a very expensive billet "race" pump. I want to build this motor so that within reason I do not have to worry about anything for a long long time. As one in the mechanical industry I do not trust reman parts at all. I have seen too many alternators, water pumps, power steering components, etc., that either failed out of the box or right after the warranty expired. As hard as it is to replace these, what are we to do??? Who are the reputable builders? Are there any?
If you want worry free for a long time, I suggest looking into bullet proofing. I found out the hard and expensive way that these 6.0's have many problems. There is a lot of info out there on how to do this.
If I had to do it over...I'd run like hell! lol
I wouldn't have a problem with a Ford or International sourced re-manufactured HPOP of the 05-10 style. It is the 03-04 HPOP that I would avoid - all but Dieselsite and CNCFab.
Many shops say that people need HPOP's when they really don't.
Reactions: 2
I wouldn't have a problem with a Ford or International sourced re-manufactured HPOP of the 05-10 style. It is the 03-04 HPOP that I would avoid all but Dieselsite and CNCFab.
Thats where I'm at, atm. I find it hard to believe that the last one I had installed has gone bad already. The shop has my truck again, they say they are doing an air compression test to look for a bad O ring. They supposedly already did that last time they had it. This time, they said said they are doing a 'more intensive test'. My question is, why didnt they do that when they had it before? I've used this shop before and have had good luck with them...now I'm having my doubts. BTW, they quoted me $5200 to replace with a reman HPOP. smh... Hopefully they find a bad O ring
Wow. That is abuse IMO. I just can't see why it would be that much. You can buy your own pump for $650-$800.
What brand HPOP was installed last time?
Bostech, Delphi, DTech, Dorman, Sinister - I would stay away from for sure. Bosch and Alliant - who knows. It would be nice to know what companies actually did the re-manufacturing for all of these.
I have been researching 6.0s for about a year now. The truck (2003 CC 4x4) is in fantastic shape except for the lifter that decided it was done with this world. Anyway, the truck was given to me for free, so even if I put $5-6k in the motor, I am money ahead. I have been a mechanic my whole life, own a motorcycle shop and a small machine shop, but this is my first diesel experience. I am not worried. The motor is ready to pull now and I will be doing EVERYTHING to make it reliable and strong. I will not be throwing tunes at it or anything to make big HP as I only tow 6k lbs and this motor in stock form would be more than I ever need. BTW, I believe the lifter failure was caused by a completely plugged oil cooler and excessive oil temps. This will never again be a problem on my build as I am building a oil cooling and filtration system just like the commercially available ones with some slight tweaks. Also doing heads, EGR delete, nice (but quiet) exhaust, and a host of other upgrades along the way.
See less See more
Reactions: 1
"BTW, I believe the lifter failure was caused by a completely plugged oil cooler and excessive oil temps."
I've seen this pattern too often.
Reactions: 1
It was completely plugged. No coolant could pass. I feel it is a bad design to use this type of cooler on a cast iron block. We see them all over the place in all aluminum engines with zero problems. In fact, my MB, BMW, and Wildcat XX side by side all use this style cooler with no issue. But cast iron is dirty. Even with the best coolant and regular changes you will always get some amount of block surface rust and flakes sluffing off to plug the cooler. I am going with a large, temperature controlled fan cooled air to oil cooler mounted on the front somewhere. Problem solved.
I know people feel strongly in all different directions, but 16 years and 238k miles and I have never had a plugged oil cooler. I believe that it is possible to be reliable with the OEM oil cooler, but you have to watch the system fairly closely.
Reactions: 4
This one had 188k on the original cooler and it was plugged solid. But the block has enough surface rust in it that I just do not want to go down that road again. If you bought it new, religiously maintained it with coolant changes, you may never have the problem. But sadly, this is only a small percentage of the rigs on the road. Who regularly flushes coolant, brake fluid, etc.? Not many like us who do. I feel once the rust has started, the game is over. You will never be able to go back and have a forever clean engine. This is why I am going the route I am. No water over oil cooler, no problem if there is a bit of debris in the coolant. It is expensive if you have to buy it, or a bit of a project if you are building it like me, but I think it will be worth it in the long run for this truck.
I have a machine shop and I am extensively modifying the original oil filter housing for a feed and return line to bypass the internal cooler, then running through a pair of oil filters, oil temperature thermostat and large 32 plate fan cooled cooler.
See less See more
Yeah, I agree, once it is full of corrosion, debris, etc, it is hard (or possibly next to impossible) to get clear. I know people that have successfully used the Restore Plus and the Ford VC-9, but I haven't used them. Mine was a clean system when I switched to the (far) more robust EC-1 rated ELC coolant - at about 100k miles. I haven't flushed it again since the change, and that was about 10-11 years ago. Maintaining a clean cooling system from day 1 can be a huge plus!
coolant filters get laughed at, but they work
Reactions: 2
The thing is, with the different coolant that Navistar used in their VT365 engines, the same basic engine as the 6.0L, they did not see the coolant blockage the Ford's have.
It was a wrong decision for Ford to extend the life of coolant service from what the 7.3L had or to use a coolant that was common for all their other non-diesel engines.
Once the passages start to rust, it's tough to eliminate. The VC-9/Restore Plus does work, but it's nearly impossible to get all the rust dissolved and to get it all flushed out with the standard methods.
One solution that has not been widely used with the 6.0 is the Thermo-cure coolant cleaner. I'd like to try that product if I had a rusty engine block. I used the company's EvapoRust on my head, and engine block coolant passages with the engine disassembled. It did a fantastic job of removing all the rust and not promoting rust afterward. Unfortunately, too many acid-based cleaners promote rust afterward.
Reactions: 2
i still see arguments against running ec-1 coolant in facebook groups, 10+ years of use with no ill affects convinces me they dont know wth they're talking about. switching from the ford gold was the best preventative maintenance step i ever took.
Reactions: 2
Back to the original discussion, what rebuilt HPOPs do people trust long term? I would rather not buy the billet one as I think it is overkill for my build and I am spending enough $$ already.
I answered that above. You have an 03. The DieselSite pump or the CnCFab pump. If you don't care for that advice, then try your own and keep us updated once a year.
$676 is marginally over the cost of am OEM remanned pump. The minimal amount more would be eaten up quickly by a repeat job.
Personally, I have the money and wouldn't mind spending it on the DieselSite pump. I have kept up with a few users that installed it and they have a number of years under their belt with no issues. That said, the CNCFab pump is cheaper and also has a good reputation.
Several of the weak areas of an early 6.0L HPOP have been discussed a fair bit - going back to 2011. The only people acknowledging that changes need to be made in the original design are the two companies mentioned above. Their pumps have a great reputation with the forum people that have tried them.
If you don't buy into the hours and hours of following and researching the topic as a few of us have, then roll up your sleeves and start searching.
See less See more
Reactions: 1
Bismic,
Sorry, I missed the comment earlier recommending CNCfab or Dieselsite. That is what I am looking for. I am all looking for your guys input rather than learning myself by trial and error. I will decide between their stage one or the billet pump when I get to that point in the build. I think anything more than the stage 1 is overkill for my application and intended use. But, if it will last longer, then that is a consideration.
No problem. I have spent many hours on the topic and there are even a few good discussions going on right now that include a look at the internals of both the early and the late HPOPs. There have been a NUMBER threads on the early HPOP and whether or not an OEM remanned can be made to last or not. One shop owner on another forum has adamantly stated that he NEVER had one of his installed OEM HPOPs "come back". He attributes his success to proper priming of the HPO system before starting to crank. No doubt this is a VERY good idea, but there are design flaws with the OEM pump that I would want addressed. I also think that many of the failures could be connected to significantly over-heated oil, or debris-contaminated oil, or a lack of oil supply due to a tall aftermarket oil filter cap with a shorter OEM oil filter. So, all that makes it a hard topic to actually "nail down".
My view has always been that if I paid a shop quite a bit of money to install a part, and it failed just past the (say 2 year) warranty period ..................... then I would not be taking it back to that same shop! So unless the failure happened within the warranty period, a shop wouldn't probably see the true 2 yr + failure data. I expect a LOT more than 2 years out of an HPOP reliability!
As you are, I am very skeptical of the need for higher output from an HPOP.
See less See more
Reactions: 1
1 - 20 of 29 Posts
