I was looking at a 2.5" front 1" rear leveling kit which supposedly fits 37" and costs roughly $1500 installed and the BDS four link 4" which supposedly fits 35" at $5300 installed. (fox shocks with dual upgrade stabalizers with rear leaf springs) I am going to be towing very little but still will be towing a 3000lbs trailer 3-4 times a year and a 8000lbs trailer 2 times a year... It will go off the gravel road into some muck but no means a baja truck, (light rock crawling, and 30" water holes at the deepest). Is it worth the extra money for my plans or not. Money's not the issue. I'd be able to put my leveling kit in sooner though.
This is my first post I have a 09 xlt crew cab long box single rear wheel supporting mods (afe stage 2 intake, afe 4" turbo back dpf delete, egr delete with improved intake pipe, head studs, and mini max with canned tunes.)
light weight trailer will be through mountains, heavier trailer will be on road. I'm on factory rims and factory size rubber at the moment any recommendations on the size 37x12.5 or 35x12.5 I know 37's will fit I've seen it I will need to modify the front wheel well on the 2.5"
