1 - 5 of 5 Posts
Ok i clearly have an 03 truck which means i have leafs. So my question is, What is the biggest wheel tire combo i can run with a leveling kit and i plan to put new shocks on the truck as well! As well as backspace. I would like to get fairly deep wheels in 18's or 20's with like 33/12.50's Iam open for suggestions on brands of levels and shocks as well! Thanks for the help!
My buddy is running 35 in his 04 I'm running 33 with my 3in leveling kit
I have 35x12.5x17 on my 04 with a 2.5" leveling kit.
I am running 35" 12.5/17s terra graplers on 17x9s with a Zone 3" level kit on my current 04 6.0 ccsb fx4, if you run a deep rim it will rub on the wheelwell corners. the picture in my avatar is my old 04 315/75/16s on 16x10s 4" backspace, still rubbed on a 4" procomp that measured 5" actual lift, I like my zone level kit with bilstein shocks. Wheel backspace and width are critical, I used to manage a 4x4 shop and did countless installs on leafspring Superdutys, some people even fit 315s on oem rims with no lift, 305s fit on oem rims, although 285/75s are a better choice than 305 70s(they are taller anhave a flatter footprint on the oem rims, I run them on my excursion).
1 - 5 of 5 Posts
