1 - 7 of 7 Posts
wondering if u can run a leveling kit on the front with the lifted shackles also. haven't done it just seeing if it is possible.
You'd want to run a hanger and shackle, but yes you can run say a 2" mini spring back with a 4.5" hanger and shackle to make a 6.5" lift.
Of course you need a few other parts to address steering issues for that height to have it properly setup.
i was thinking abot usine a leveling kit and shackles on the front with some 2" block in rear. what else would be needed for the steering to aligned properly???
4" total lift?
You'd need a front box kit out of a 4" lift.....pitman arm, trac bar bracket, sway bar links, etc..
Shocks meant for a 4" lift, bumstop spacers or larger bumpstops.
thanks for the info. gonna stick with a leveling kit and if the front sits a little higher just use some 1" blocks in rear so it dont have that bulldog stance.
1 - 7 of 7 Posts
