ok. The only part i'm not sure about is if you have your park lights on then put on the brakes does that make the current/voltage through the led's higher than if you had the park lights off and hit the brakes?Pretty much installed a resistor so the LEDs were at maximum rated current/voltage for the brake/signal. I added another resistor so they would be dimmer for the park light.
and i followed that link from the bmw forum you posted to wire themhere's some pics
this is the tail light with the lense and red reflectors taken off
this is the lense once it used the vht red night shade to tint it
this is the board when i was fitting it to the light
this is the back of the led panel
this is the front of the led panel
passenger led kinda from the side
entire back of truck
