1 - 20 of 29 Posts
This is a '15 F-350, SRW, 4x4.
I've been meaning to post this for a little while - noticed evidence of a seep/leak from the driveshaft seal from the transfer case (see attached). It's pretty dry and there's never been any "evidence" on the driveway, nor is there any underbody "blow-by".
Should I be concerned? Anyone else see this?
Administrator
@voodooridr sometimes helps us with part # even though he has nothing though gain from it
that is a booted seal so the outside that looks like cracked chit on yours is a debris shield for the actual inside seal ( in case anyone wondered why they don't look like a normal t case seal )
They're cataloged in the transfer case parts list so I'd need a transfer case tag # or a vin# to find it without guessing
It's most likely a 7C3Z-7B215-A, assuming electronic T/case and auto hubs
Sent from my XT1080 using Tapatalk
Started life as. DC3Z-7B215-A and was "updated" to the older number
Here's the T case tag. I can provide VIN also if needed.
Yes, electronic shift and auto hubs
So are they no longer doing the boot? I never had a squeak. I kinda like the idea of it protecting the other seal instead of having it exposed to the environment. But if you say run it without the boot, I will.
The 7C3Z-A should get you where you need to go, check the vent hoses too, shouldn't be seeping yet
Didn't look at previous posts, looks like someone grabbed it with a pair of channel locks
The outer boot is very brittle. I barely touched it and it fell apart like that.
It also appears that the slip yoke starts to rust where the seal doesn't contact often. Then under occasional circumstances the yoke will travel enough that the corrosion will contact the seal/boot and rip it. I'm thinking the yoke might need a little exterior cleanup and greasing in order to keep it smooth and healthy.
Ford is on back order over a month out. It looks like eBay might be a possibility. I also got a seal from NAPA that's supposed to work. Part number 21241. will probably tear into it this weekend to try and fix it. I'd just hate to get it torn apart and find out I can't use my truck because I don't have the right seal.
Thanks for the guidance. This is such an annoying little problem.
There about 120 of them floating around in the Ford warehouse network, Shouldn't be more than a few days away where ever you are
that looks like the older version,, like mine would use
but maybe ford reverted back / since I did hear they had some squeaking issue
somone give up a vin ;-)
That's a 7C3Z-7B215-B, that would be correct for the front output seal
Administrator
granted it is leaking and needs replacing
and if it makes you feel better about losing the boot , typically most rear seals are bootless anyway and fair better than this one
sure the boot is nice but it would be nice if they had a boot that didn't dry rot in such short order LOL
Administrator
?? thats the part # you listed for the rear ?
EDIT NM I see the B instead of an A crazy same part # but i letter changes it all lol
Uh, no
Even though I had to scroll back up and look
7C3Z-7B215-A for the rear output
7C3Z-7B215-B for the front output
they are toying with us
Welcome to my corner of hell.
That's why really good Ford parts guys are hard to come by
Uh, no
Alright I'm gonna throw another wrench in here. What about part number BC3Z-7052-C
It looks pretty close to what I need. But possibly discontinued...
1 - 20 of 29 Posts
