1 - 17 of 17 Posts
i can't get a straight answer for this so hopefully somebody can help. my up pipes are leaking, bad. i heard i need to replace the pipes because they don.t use a gasket, the expand with heat to make the seal. then i have hear that they use a gasket. also they say i will need a turbo y manifold because i will break the bolts off from the up pipes. also whats the chevy doughnut gasket about. some body please help set it straight!
Ok...I just replaced mine...
No gaskets,...and yes...there is a chance you will break the bolts....spray a lubricant on them a couple days before you plan on working on them.
The pipes normally break in the "bellows" sections...
If it aint a CAT itsa DOG
This is on a 7.3 though. I think the 6.0's are different. I have heard that there is a gasket on the 7.3 up pipes and that ones for a chev small block actually fit better then the factory ones.I'd also say that there is a chance of snapping off some bolts because they can get very rusty.
i do it all the time tank without reading, its no problem
The lower part of the upipes seal right on the exhaust mainfold, no gasket, the top have the gasket as far as I know but I dont know the #s for the chevy doughnuts. The y pipe takes alot of heat so the bolts rust in there pretty good, soak them with PB blaster for a good few days, and have a replacement y pipe on hand in case you snap a bolt, can always return it if you can use the OEM one.
yeah i think its the top seals that connect the up pipes to the turbo collector.
get the chevy donuts or the IH bellowed up pipes
Discussion Starter #12
i would love to get bellowed up pipes but money wise im not sure, what did that set up cost? could i just replace the doughnuts and not the pipes? Also what chevy are the gaskets out of and do they work better than stock ford ones? thanks
The Fel Pro p/n for the chevy donuts is 8194, under 8 bux at NAPA for the pair, mine have 20k on em without a leak, spray the bolts heavily with PB Blaster the night before, do it again in the a.m., wait an hour and your bolts should be ok when removed.
Served Our Country
Do you have to pull the turbo to change these gaskets?
1 - 17 of 17 Posts
