1 - 5 of 5 Posts
Well I had the Ventrui Tee put on my truck after the modification I keep getting fluid pouring out of my Radiator Cap? I'm hoping its not the head gaskets but is there anything else it could be? I'm going to order a new cap Monday it only happens when I really stomp on the truck just driving regular it doesn't happen at all. Over 50 PSI and theres fluid all down the left side of the fender well you can see where the fluid is hitting the hood from the cap?
I wanna go fast!
There are tons of posts both on the garage and Spartans website all with the same issue.
so whats the solution
Discussion Starter #4 (Edited)
From what I read nothing? I need to figure out what the hell is going on? I'm gonna take that damn tee off and see what happens. I don't think its the headgasket with 4-10 trucks doing the exact same thing. Its posible that the water pump idea is pluasable? Well I'm gonna start doing the pressure test, replacing the cap, and the resivor. I have the 275 Tune.
im on em on the other two sites different name
1 - 5 of 5 Posts
