1 - 13 of 13 Posts
do i have oil dripping down my bell housing and onto my front drive shaft, no idea where it comming from? anyone had this problem before? maybe a vlave cover gasket?
i will give alittle more detail, looks to be comming from on the head somewhere, freeze plug? harness? valve cover? seems to be running down from up in that area and dripping down the bellhousing onto the front drive shaft where the boot is. I do ALOT of highway driving and the truck only has 62k on it, had one injector replaced on it. (broke a gasket? seal? at dealership?) also it seems to smell on long trips say over 2+ hours on the highway, seping alittle maybe hitting an up pipe? its not bad at all but im just a perfectionist. think i should worry about it or just takel it when i do studs and everything... im assuming in the next 10k
im not sure what side it was on. was down prior to me buying the truck, wondering if other people have had similar issues
i took a picture tracked it too up top of the engine but still dont know what its comming from....
here is what i could take a picture of anyone got ideas?
has anyone seen this issue? dripping down the back of the motor? maybe coming from under the turbo? how hard is it to pull the turbos? cab on possible? all input needed!
Turbo oil Line (return or feed) maybe?? Take off some shields and start digging deeper...
Discussion Starter #12
if i take the sheilds off can you see the feed lines??? never had them off before.
I has the same issue but never had the time for looking for
1 - 13 of 13 Posts
