donut oring?? my leak is very unsteady. it never seems to be dripping, doesn't seem to be burning it at all, and in the most random mornings there will be a pond. i can't figure it out. its going to a shop soon because its starting to concern me. the hose at the bottom of the reservoir for the coolant isn't leaking (although it looks like it would), the hose clamps are now tight on the blue hose that goes from the coolant delete piece to the manifold by the valve. there was a little random coolant on a plug between where the valve would be and the filter assembly, but i cleaned it off and it hasn't happened again. the oil seems ok, its not milky white (although it doesn't look jet black like i thought it would), i'm not as concerned that its getting in the motor only because of the puddles i'm leaving behind.. hope that explanation was a bit more helpful
