How many leafs do you have in your f350 single rear wheel I had 5 plus a helper now the replacement have 6 plus a helper confused should I go ahead and use?
I have the same question on the front springs. I have 2 but it looks like there used to be a 3rd leaf, possibly some kind of helper, on top. I have 5 plus the helper in the rear.
My 97 F350 from the factory has 5 Rear leafs with the top leaf as the Overload. The front D60 came with two leafs and I installed the Add a Leaf to level the truck. 5 rear 3 front. The ride is anything but smooth with the added leaf on the front axle.
Ya now when I was cutting off the old hanger from the junk yard I put a small cut onto the main leaf with the bushing not sure if I should run it or replace it....
