the front leaf springs on my 95 power stroke look like they are arched backwards and mainly its the passengers side but the tire is leaning in from this the only way i know is because when i jack it up the whole leaf spring will straighten back out and fix my tire leaning problem. It also looks like the passenger leaf spring on the back side of the axle looks like the middle and bottom leaf are moved over the top one looks fine but the other two looks like they moved over to the side and the bracket that is on the leaf springs that look like they are holding the leafs to gather the one that is behind the axle but not the one that holds them to the frame is loose and it wiggles do u think adding another leaf to it will make it raise up straiten the tire out.
