late HPOP test device build
4288 Views 55 Replies 7 Participants Last post by  bismic
6
Hello Gentlemen,
I would like to build a device to test second/late generation HPOPs.
To see how they work I have started to disassemble a pump.
Can anyone tell me how these inserts are fixed in the housing? I can't hammer them in, nor can I pull them out with an impact hammer.
See less See more
21 - 40 of 56 Posts
Regular 9 volt "transistor radio" battery works well and is easy to find -- for the new generation kids, that is a smoke alarm battery
You think anyone changes those batteries???
Now I must admit I have three of them in my dual-mag timing box.
Had to look that one up, didn't know there was a fancy tool to set timing on a mag -- I just use the beeper on my meter to time the contacts with the magnets -- Maybe agricultural mags and aeronautic mags are different <shrug>
9 volts ? --no, not until the smoke alarm starts beeping and being annoying
Aircraft just has two of them on the engine. It just gives you two different tones. One for each mag.
Makes it easy when your checking the setup.
I think some people gust rip them down when they start to beep and or pull the battery and then forget about them.
Not the best practices. Once one of mine start to beep it time for a box of fresh batteries and all of them get done.
When I had the gerage fire it was the kitchen detector going off that made me look to see where the smoke was
coming from and then get mom out of the house. I also got the cat out. Then tried to see if I could do anything.
4
The inside of the pump is very simple. In principle, nothing is inside that could break down.
If such a pump fails, it can only be caused by one or more of the 4 valves failing, otherwise there is nothing inside that could fail.
I also have an 03 engine and will also disassemble the 03 pump. These have much more common problems as we all know.
See less See more
Reactions: 3
Very simple valving. Is there a key on the shaft or is the gear just a press fit?
the shaft is slightly conical. The power is transferred only by friction between the shaft and the gear (as with the steering pump).
@sean: the gear sits tight on the shaft, it needs a puller to loosen it, I don't understand it like that issue with
blicharski1989´s pump (FTE thread) could happen.
I have a theory, but I'm waiting to see if he loses another pump. I don't want to get him worried for nothing.
That is a similar pumping principal to the old Ford 801 hydraulic pump (form the 50's or 60's) -- the main difference was the 801 pump used an axial piston arrangement with a rotating "swash plate" -- a hole in that plate acted as the intake valve
Looks like Ford used the same basic principle for the HPOP in these trucks -- what is old, is new again, ....LoL
Actually a grease gun works in a similar fashion
I wonder how the 4 valves can be removed without force. There are reman pumps. That means it must be possible to replace the valves.
The sleeves that fix the "cam" are also only pressed in.
The right gear wheel in the picture is from a 05 pump. Why is the gear narrower than on the 03 pumps?
As far as I know, the gears on the cams are the same on early and late engines?
Household hardware Gas Tool Auto part Wood
See less See more
My theory:
Possible fracturing (from alignment) of the teeth in the wider gear, if the shaft bearing got worn
The gear looks like made from cast iron -- the narrower gear would allow more movement in the alignment before breaking teeth
Hmm, this would be a explanation. Both are cast iron. I would have to measure both cam gears, have early and late cams here...
Automotive tire Gear Bicycle part Rim Wood
See less See more
I must correct myself: only the late pump has a conical shaft and gear. With the early pump, both are cylindrical!
Photograph Automotive tire White Crankset Product
With the early pump, a half turn of the central screw counterclockwise is sufficient for the gear to become loose and no longer drive the pump!
See less See more
Reactions: 2
And no one has the torque spec on those. They come with both a 10.9 and 11.9 spec bolt. The unusually 11.9 spec is in the TTY territory. Our head bolts are 11.8.
The one you have there is a 10.9 6-point. The 11.9 is a 12-point hex.
As I mentioned over at FTE, there are different castings to these.
With the normal rotation direction, the bolt holding the gear would remain tight -- so I don't see the bolt "backing off" ever being a problem
I thought so too, but in this post the screw has come loose.
Why is still unclear.
Post #431
Post #431
Thanks for the link to that thread -- I suspect the friction fit of the gear is to protect the cam gear, in case the pump locks up (also cheaper to manufacturer) kinda goes with the press fit swash plate idea
That makes sense that it's to protect the cam gear if the pump did lock.
21 - 40 of 56 Posts
